HS4 Smart Home Automation Software
Build Your Own Hub!
Our smart home software has been the preferred platform for DIY smart home hub builders for more than 25 years.
Locally Managed Home Automation Software for Windows, Linux or Raspberry Pi Computers
Smart Home Software for Every Need & Budget
HS4-Software-1000
Smart Home Software
Turn any Windows, Linux or Raspberry Pi computer into a powerful smart home hub with HS4!
Smarter Home Automation. Built for DIY
25+ Years of Experience
For more than 25 years, our smart home software has been the go-to platform for DIY smart home hub builders. Whether you’re a hobbyist setting up your first home automation system or an experienced developer creating complex automation workflows, our platform has provided the flexibility, reliability, and control that DIY enthusiasts need to bring their smart home projects to life.
Local-First Control
Unlike many cloud-dependent solutions, our smart home software operates locally, ensuring that your home automation systems are not reliant on external servers or internet connectivity. This not only enhances the privacy and security of your home but also provides faster response times and greater control over your devices. This local-first approach provides several advantages, including reduced latency, increased reliability, and greater control over your home’s automation processes. It also allows for complex automation scenarios, where devices can interact with one another without the need for cloud-based processing. Whether you’re integrating sensors, smart lights, security cameras, or even custom-built devices, our software enables you to manage everything from a single, locally hosted platform.
Flexible Platform Options
Our software is compatible with a variety of operating systems, including:
  • Windows for high-performance hubs
  • Linux for maximum control
  • Raspberry Pi for affordable, compact builds
This gives users the flexibility to choose the hardware and platform that best meets their needs. Whether you’re using a high-performance server, a low-cost single-board computer or anything in between, our software can be installed and optimized for your specific setup, allowing you to create a fully customized, locally managed smart home hub.
Proven & Scalable
Tested and refined for more than 25 years, our software grows with you. Start small and expand over time into a fully automated, secure, and scalable smart home system.
Why Choose HomeSeer?
Reliable & Fast
Automations are processed locally for the highest level of performance with no delays.
Safe & Secure
All your information is stored on your system at home, not in the cloud.
Independent
Automations continue to fire even if your Internet connection goes down.
Compatible
HomeSeer works with thousands of popular products from hundreds of companies.
Voice & More
HomeSeer is compatible with Amazon & Google smart speakers & with IFTTT.
Future Proof
Our systems don’t rely on a cloud service. Your smart home investment is secure.
Smart Home Apps
Our mobile apps provide easy and powerful ways to monitor and control your HomeSeer system!
HomeSeer Mobile
Our Standard App
HS4Touch
HSTouch Mobile App
Fully Customizable Control!
Attention HS3 Users!
Looking for reasons to upgrade?
We’ve got a page just for you
See What Others Are Saying
James M
5 Star Rating
“Best Automation Software Ever! I’ve tried Smartthings, Home Assistant, Vera, and Donomitcz and HomeSeer is by far the best and most compatible system I’ve used. Also response times are incredible, no more waiting for the request to go out to cloud and back. Also works great if your internet goes down.”
Steve A
5 Star Rating
“Homeseer HS3Pro My conversion for Vera Edge has been fairly painless, although some of the Homeseer UI isnt as easy to use, the biggest gain is MQTT and control over what running on my home controller. The homeseer store transaction was easy, and homeseer support has been excellent.”
Aaron
5 Star Rating
Works better than all the others.
I’ve used ISY (for 5 years), Vera (for 5 years), Wink, InControl, and several others briefly OpenHAB, Home Assistant (HAS), and smaller players. While HomeSeer is more expensive, it is far more stable than Vera and far easier to setup than the free alternatives like HAS & OHAB.
David W
5 Star Rating
“Flexible Home Automation HS3 is by far the most flexible home automation software. This is definitely one of those you get what you pay for scenarios. HS3 has the largest amount of things it works/integrates with and it’s flexibility is always increasing. Very happy with my purchase!”
Need Help Sorting Things Out?
This website uses cookies
