Phone Keypad Command Summary
When calling HomeSeer Phone, you can give voice commands or use the keypad on the phone to navigate the menus. Depending on the how the system is set up, the commands may differ. Here is a summary of the available keypad and voice commands. Note that voice recognition is not enabled for normal callers who are not logged in. All the commands described here are set in the default command scripts. These scripts may be edited to change the prompts or the keypad commands. See the Command Scripts section for more details.
If the system is set to use the single mailbox command script (set in the Phone Setup screen), the caller is prompted to simply leave a message. The message is left in the default mailbox.
If the system is set to use multiple mailboxes, the caller is prompted to enter a mailbox number and the pound (#) key.
For either system (single or multiple mailboxes), the caller may enter their passcode by first pressing the pound (#) key. This causes the system to prompt the caller for their 4-digit pass code. After successfully entering their passcode and the # key, they are now in their private mailbox. They may also access the default mailbox by entering the associated passcode.
After logging in, you may enter commands using the keypad on the phone or by using voice commands. Here is a summary of the available commands.
Keypad Command
Voice Command
Mode Available
Action
[mailbox number] then #
N/A
External call, multiple mailbox mode
Puts the caller into the given mailbox. The caller may then leave a message. After leaving a message, the caller may enter another mailbox number or press # to hang-up.
Pound key (#)
or
star + pound key (*#)
N/A
All external calls
The system prompts the caller for their pass code
2 + pound key (2#)
Help*
All
Speaks the available commands
1 + pound key (1#)
messages*
After login
Gives access to your voice messages and email messages
9 + pound key (9#)
goodbye*
After login
Logs you off and hangs up the phone
[keypad digits] then #
N/A
After login
HomeSeer events may have a 2- to 4-digit DTMF (touch-tone) command assigned to them. When the digits entered on the handset match the digits assigned to the event, the corresponding event is triggered.
3 + pound key (3#)
N/A
After login
Sends X10 commands. Follow the prompts to enter the house code and unit code of the device to control. Devices may be turned on or off.
4 + pound key (4#)
N/A
After login
Enables the speaker phone speaker for paging through a whole house audio system. If this command is given from an internal phone, you must hang up after paging. If the command is given from an external call, you can still give voice commands and keypad commands while the speaker is active. This command is only available with the HomeSeer PCI Voice Modem.
Star (*) key
N/A
After login and only when the line is ringing
If an external call arrives while you are on the phone with the computer, you can press the * key to grab the call. The computer will notify you if a call arrives.
Star (*) key
N/A
From an external call in multiple mailbox mode
When the system is waiting for a mailbox number, this key will cause the system to speak the mailbox directory.
N/A
"leave a message for [mailbox name]"
or
"leave a message"
After login
Allows you to leave a message for another user. The user must have a mailbox configured. To leave a message in the default mailbox, say "leave a message".
N/A
(call or dial) [name]
-- defaults to home phone
or
(call or dial) [name] at work
or
(call or dial) [name]'s cell phone
After login
Allows you to dial a entry in your address book. For example. If you have an address book entry of "Bill Smith". You could dial Bill by saying "Call Bill Smith". You can also say "Dial Bill Smith". This command is only available if you are calling from an in-house phone using the HomeSeer PCI Voice modem or the Hi-Phone device.
If the address book entry contains an area code, and the area code matches the local area code as set in the options, the area code is not dialed.
N/A
Dial [number]**
After login
Dials the spoken phone number. For example, you could say:
"dial 5 5 5 1 2 1 2". You hear a confirmation of the spoken number.
N/A
Any HomeSeer voice command
After login
Executes the recognized HomeSeer voice command. The voice command must be configured in HomeSeer to be recognized over the phone.
* These voice commands are the defaults. They can be changed in the internal IVR script.
** These commands are only available for use with the HomeSeer PCI Voice modem or Hi-Phone device.
