Returns a collection of all plug-in objects, one object for each plug-in enabled.
This returns all plug-ins - use GetPlugins if you want a collection of all plug-ins that are known to support COM interop. Be aware that not all .NET plug-ins were written to support COM interop (e.g. They may not work with older scripts or other COM plug-ins - they may work only with VB.NET scripts and .NET plug-ins if they were not written to support COM interop.) When a plug-in fails to provide a COM interface, the plug-in reference will still be included in the collection of plug-in objects, but calls to any of the properties or methods of the plug-in will fail. A test procedure with error checking should be used to make sure your scripts do not unexpectedly abort due to this.
None.
Return value: plug-in
collection
Type: collection
Sub Main()
Dim pi
Dim p
Dim s
On Error Resume Next
' Get a list of All plug-ins,
COM and .NET
Set pi = hs.GetPluginsEx
hs.WriteLog "Plugin List","There are " & pi.count & " plug-ins in the system."
' Now, list all COM plug-ins,
or .NET plug-ins that have a COM interface.
For Each p in pi
Err.Clear
s = p.Name
If (Err.Number <> 0) Or (Trim(s)
= "") Then
'This is probably a .NET plug-in
without a COM interface.
Err.Clear
Else
hs.WriteLog "Plug-in",s
End If
Next
End
Sub
