PowerFailRecover
Purpose
This command will trigger a power failure recovery operation similar to the one that is started automatically if it is enabled in the system configuration.
The recovery takes place using the number of hours set in the power fail options, and it starts from the time an event was last run successfully on the system.
Parameters
None.
Returns
None.
