This call registers a help link resource with HomeSeer so that it will appear on the help (/help) page of HomeSeer. This function can be used by both plug-ins and scripts.
This procedure only works with HomeSeer HS2 versions after 2.2.0.0
Parameter: link
Type: String
Description: This is the actual URL link, and it is case sensitive if it
refers to a plug-in registered web page and with some external web pages.
If you
are referring to a help resource on the local system under the HTML directory,
it should start with "/" so that it is referenced relative to
the root of the HomeSeer web server. If
it starts with http: or ftp:, a note will be appended to the link letting
the user know that an Internet connection is required to access the link.
Parameter: link_text
Type: String
Description: This is the text that will be displayed for the link on the
help page.
Parameter: plug-in
name
Type: String
Description: This is the plug-in name or some sort of unique identifier
for a script or ASPX based system. This
identifier is used to group multiple links from the same plug-in or script/ASPX
together, and it is displayed as a heading on the help page. It
is not required that a plug-in use its IFACE_NAME value, but it is necessary
to use the same text when you use UnRegisterHelpLinks.
For example,
if your plug-in name is "MediaPlayer", you can instead use "Windows
Media Player" so that the title is more descriptive.
Parameter: order
(Optional)
Type: Integer
Description: This is an optional parameter that is used, if provided, to
set the order in which multiple links from the same plug-in or script/ASPX
are displayed. If
there is a preference as to the order that multiple links under the same
heading (plugin_name) are to be displayed, then set the first one to be
displayed to have an order of 0, the next one to 1, then 2, 3, 4, etc.
This parameter
MUST be used if multiple links from the same resource are registered.
None.
hs.RegisterHelpLink("/MyApplication/MyHelpFile.htm","Help For Cool App", "My Cool Application")
