UnRegisterGenericEventCB
Purpose
This will remove an application or plug-in from the list that should receive generic event callbacks for the type indicated (See RegisterGenericEventCB).
Parameters
Parameter: Generic Type
Type: string
Description: This is the generic type string that was used to register the callback with RegisterGenericEventCB.
Parameter: Object Name
Type: string
Description: This string should contain the name of the object as it was obtained by HomeSeer when RegisterGenericEventCB was called.  The specific name is input here instead of the object so that the UnRegister can take place even if the original object was destroyed.
Returns
None.
Example
' Unregister a generic callback or two...
Sub UnRegisterGeneric()
hs.UnRegisterGenericEventCB "MyPlugEvent", PI_Name
 ' Or to receive all Generic Types...
hs.UnRegisterGenericEventCB "*", PI_Name
End Sub
