This function returns an event. The event is of type EventClass and can be used to retrieve and set properties of an event.
An EventClass has a number of properties that holds information about an event. You can access these properties to get and set this information. The function NewEventGetRef can be used to create a new empty event. The properties of the event are listed below.
Parameter: event
reference ID
Type: long (.NET Integer)
Description: This is the event reference ID of the desired event.
Return value: EventClass
Type: object
See EventClass
