NewRecurringEvent
Purpose
This function creates a new event with the trigger set to a specific time.  The event is initially created DISABLED.
Parameters
Parameter
Type
Description
evname
string
This is the name that will be given to the new event.
min
interger
This is the time interval in minutes the event will trigger (1 = every minute).
m
boolean
TRUE = include Monday
t
boolean
TRUE = include Tuesday
w
boolean
TRUE = include Wednesday
th
boolean
TRUE = include Thursday
f
boolean
TRUE = include Friday
sa
boolean
TRUE = include Saturday
su
boolean
TRUE = include Sunday
devices
string
This is a string with a list of device-command combinations like "B2:on,b3:dimto-50". Valid commands are any X10/ZWave command along with the following:
dimto: Dims the device to the specified value using the current dim level.  If the device was at 20% and the command "B2:dimto-50" was given, the actual X10 command sent would be "B2 bright 30%"
dim or bright: Will first send a bright 100% to the device then dim to the specified level.
dimr: Will do a relative dim and simply send the dim value. If the command was "B2:dimr-30", the X10 command "B2 dim 30" would be sent.
brightr: The same as "dimr" except the X10 bright command is used.
DeleteWhenTriggered
boolean
This is either TRUE for delete the trigger after it triggers or a FALSE to not delete it.
scr
string
This is the name of the script to run.
group (optional)
string
This is the group the event will appear in. This can be a new group. This is optional and may be omitted.
Returns
Return value: status
Type: boolean
Description: This returns TRUE if the event was successfully created and FALSE if it wasn't.
Example
The following would create an event name "newone" and run the script "check.txt" every minute only on Monday:
hs.NewRecurringEvent "newone",1,1,0,0,0,0,0,0,"",0,"check.txt","my group"
