SaveEventsDevices
Purpose
If an event or device was modified by a script, this function should be called to update HomeSeer with the changes.  For example, if you change a voice command in an event, calling this function tells HomeSeer to re-initialize the voice recognition so the new voice command is available to the user.  This function will also update all displays in the Control screen.
Parameters
None.
Returns
None.
