This function returns the "pause" status of a specific speaker client (host or host:instance).
Parameter: host
Type: string
Description: Leaving this a null string will return the status for the
first instance HomeSeer finds, otherwise use the hostname of the computer
you are interested in determining the pause status of. If
more than one instance of the Speaker application is running on "host"
then you may need to specify the instance as well in the format host:instance.
Return value: pause
status
Type: integer (.NET Short)
Description: Bit encoded value indicating the status as follows:
Bit Values |
Status |
Bit 1 = 0 |
No Wavefile Instance |
Bit 1 = 1 |
Wavefile Present |
Bit 2 = 0 |
Wavefile Paused |
Bit 2 = 1 |
Wavefile Playing |
Bit 3 = 0 |
TTS Present |
Bit 3 = 1 |
No TTS Present |
Bit 4 = 0 |
TTS is currently speaking |
Bit 4 = 1 |
TTS is not speaking |
