This function returns the volume of the requested channel.
Parameter: channel
Type: long
Description: Use 0 for the left channel and 1 for the right channel.
Parameter: device
id
Type: long
Description: This is the ID of the
device to get the volume from. 0
is normally the system sound card.
Parameter:
host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first
instance HomeSeer finds, otherwise use the hostname of the computer for
this command. If
more than one instance of the Speaker application is running on "host"
then you may need to specify the instance as well in the format host:instance.
Return value: volume
level
Type: long
Description: This is the current volume
level of the requested channel. The
range is 0 - 20.
