IsSpeakerBusy
Purpose
This function can let you know if a specific speaker client (host or host:instance) is currently busy speaking or playing WAV audio.
Parameters
Parameter: host
Type: string
Description: Leaving this a null string will return the busy status for the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in determining the busy status of.  If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Returns
Return value: busy status
Type: boolean
Description: TRUE indicates that the speaker application instance is busy.
