This is a read/write property. This function sets the file name that is to played using the speaker client. Call MEDIAPlay to actually start playing the selection.
This property may be read to get the selection currently playing.
Parameter: filename
Type: string
Description: This sets the file name of the media selection to play. The
file name may be any valid file supported by the Windows® Media Player.
Parameter:
host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first
instance HomeSeer finds, otherwise use the hostname of the computer for
this command. If
more than one instance of the Speaker application is running on "host"
then you may need to specify the instance as well in the format host:instance.
None.
