This function instructs the Windows® Media Player to pause the currently playing selection. The selection may be resumed by calling the hs.MediaPlay function.
Parameter:
host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first
instance HomeSeer finds, otherwise use the hostname of the computer for
this command. If
more than one instance of the Speaker application is running on "host"
then you may need to specify the instance as well in the format host:instance.
None.
