MediaUnPause
Purpose
This function instructs the Windows® Media Player to resume the currently playing selection.
Parameters
Parameter: host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first instance HomeSeer finds, otherwise use the hostname of the computer for this command.  If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Returns
None.
