MediaVolume
Purpose
This is a read/write property.  It sets and gets the current volume level of the playing media selection.
Parameters
Parameter: level
Type: integer (property)
Description: This sets the volume level.  100=full volume and 0 is the lowest volume.
Parameter: host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first instance HomeSeer finds, otherwise use the hostname of the computer for this command.  If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Returns
None.
Example
sub main()
' get the current volume level
dim level
level = hs.MediaVolume
' set the volume to full
hs.MediaVolume = 100
end sub
