This function temporarily mutes the speech output. By setting this property to FALSE, all speech output is silenced until this property is set back to TRUE. This mutes ALL speech, including speech generated from scripts.
This is a read/write property.
Parameter: mode
Type: boolean
Description: Use TRUE to have speech output silenced and FALSE to have
it enabled.
None.
' stop all speech output
sub main()
hs.MuteSpeech = TRUE
end sub
' enable all speech output
sub main()
hs.MuteSpeech = FALSE
end sub
