This function plays a specific WAV file out the default audio device. For more control over playing WAV files, see PlayWavFileEx.
Parameter: filename
Type: string
Description: This is the complete path
to the WAV file to play.
Parameter:
host (optional)
Type: string
Description: Leaving this a null string will apply the command to the first
instance HomeSeer finds, otherwise use the hostname of the computer for
this command. If
more than one instance of the Speaker application is running on "host"
then you may need to specify the instance as well in the format host:instance.
None.
