UnMuteAudio
Purpose
This function resumes all speech and audio of a specific speaker client (host or host:instance).
Parameters
Parameter: host
Type: string
Description: Leaving this a null string will mute the first instance HomeSeer finds, otherwise use the hostname of the computer you are interested in muting.  If more than one instance of the Speaker application is running on "host" then you may need to specify the instance as well in the format host:instance.
Returns
None.
