Bluetooth Connector
From HomeSeer
The Bluetooth Connector plugin allows HomeSeer to interract with Bluetooth devices.
[edit] Features
- Supports both the Microsoft and the Widcomm Bluetooth Stacks
- Supports RSSI (signal strength) on the Widcomm stack only
- Currently supports 3 polling methods (Connect to Service, Discover Services, or AutoDiscovery).
- The AutoDiscovery method does not support signal strength, as it does not connect to the device (It uses BT discovery packets).
- Configurable polling interval for each device
- Autocreates HomeSeer device for each BT Device, or use any existing (pre-created) HomeSeer device.
- You can rename the Bluetooth device to anything you want in the HomeSeer status page.
- Polling for each Bluetooth device can be independantly Enabled / Disabled from the web configuration interface.
- Additional "Device lost confirmation polls" configurable for each device.
- Supports setting multiple device strings and values based on signal strength through the plugin web configuration interface.
- Bluetooth client can run on remote computers (even over the internet), and report to the main plugin.
[edit] Usefull links
- Bluetooth Connector plugin discussion forum : [[1]]
