PLCBUS Connector
From HomeSeer
Jump to: navigation, search
The PLCBUS Connector plugin allows HomeSeer to interract with PLCBUS devices. The plugin has been tested with HomeSeer 2.2.0.66 and PLCBUS interface #1141 from www.x10-hk.com (with latest firmware).
[edit] Features
  • Web Configuration Interface for all features,
  • Scripting API for all features,
  • Add and Remove PLCBUS Lamp modules,
  • Add and Remove PLCBUS Appliance modules,
  • Add and Remove PLCBUS Scenes,
  • ON / OFF / Direct DIM / HomeSeer status request support for all PLCBUS modules,
  • Standard X10 command support (A1 ON, All lights ON, All units OFF... etc),
  • Default Dim Ramp Rate and On Behavior for Lamp modules (can Preset Dim to specific Dim Level instead of standard ON),
  • HomeSeer Module Polling support,
  • PLCBUS Automatic UserCode discovery,
  • PLCBUS 3-Phase support (Commands are sent to the 3-phase coupler),
  • PLCBUS Command acknowledgment (warning in the HS log in case a module didn't acknowledge a command)
  • PLCBUS Tools,
    • get inuse addresses
    • get only on addresses
    • change module address
    • get signal strength and noise level...
    • Erase all scene addresses from a module
  • PLCBUS Scene Management (several PLCBUS modules respond simultaneously with their own settings (dim level and ramp rate) to the same Scene address)
    • Scene definition (Module on/off/preset-dim DimLevel, RampRate)
    • Scene Address programming (easily program modules for scenes)
    • Scene Address erasing (easily delete a scene)
    • Scene module status (when HS receives or sends a scene command, all module status are updated)
[edit] Usefull links
  • PLCBUS Connector plugin discussion forum : [[1]]
[edit] Other plugins by stipus
Personal tools
