Click here for Messaging and Phone Voice
Commands
Click here for information on how to format voice recognition commands
in events and scripts
There are many different voice control commands available in HomeSeer. Before discussing the device, event, and reminder specific commands, there are some time modifiers that apply to each of those which should be discussed first. In all of the format descriptions listed here, words or phrases enclosed in brackets ([ and ]) are optional. Multiple choices of required words or phrases are shown enclosed in < and > symbols. For example, the phrase diagram "Turn [the] light <on | off>" indicates that you can speak Turn the light on, Turn light on, Turn the light off, or Turn light off.
The General tab of the Setup pages has three settings related to voice commands and are:
Speak Recognized
Voice Commands
When this option is set to Yes, commands that you speak are spoken back
to you by HomeSeer. This
is not a confirmation, the command is carried out, but this will let you
know if HomeSeer heard what you wanted it to hear.
Confirm
"All" type voice commands (e.g. Turn On All Family Room Lights)
If this option is set to Yes, you will get a confirmation question prior
to HomeSeer carrying out any "All" location device commands.
"Confirm
"In" and "On" voice commands even if the device confirmation
is turned off
When this option is set to "Yes", a command such as "In
20 minutes turn on the kitchen light" will be confirmed even if the
kitchen light device is not set for voice recognition confirmation.
Many of the commands the system supports allow you to delay the start of the command or provide a time period until the command is reversed. These are time modifiers and take one of these forms:
Future Time Period
in <1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|16|17|18|19|20|30|40|50|60|70|80|90> <seconds|second|minutes|minute|hours|hour|days|day>
Example: in
20 minutes
in
2 hours
Duration
for <1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|16|17|18|19|20|30|40|50|60|70|80|90> <seconds|second|minutes|minute|hours|hour|days|day>
Example: for 15 minutes
for 1 hour
Future Day
[next] <today|tomorrow|Monday|Tuesday|Wednesday|Thursday|Friday|Saturday|Sunday>
Your computer's globalization settings will replace the above day names with the ones used on your system.
Example: tomorrow
Next Wednesday
Future Time
at <1|2|3|4|5|6|7|8|9|10|11|12> [<oh
clock|oh>] [<1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|16...58|59>]
<AM|PM|In The Morning|In The Afternoon|In The Evening>
Example: at 6 oh 4 in the evening (means:
6:04 PM)
at 3 oh
clock in the afternoon (means:
3:00 PM)
at 11 45
PM (means:
11:45 PM)
Future Date
[<this month|next month> [on]] [on <January|February|March|April...December>] [the] <first|second|third|fourth...thirtieth|thirty first>
Your computer's globalization settings will replace the above month names with the ones used on your system.
Example: next month on the twentieth
on April
first
this month
on the twenty second
In the device properties for each device, enable this option (checkmark visible) if you want to be able to control the device by voice. A voice command will be created in the following formats (Note: You can also specify confirmation of voice commands per device on the device properties page.)
For all devices:
[<turn|shut>] [on] [off] [the] [<device location|device location2|device location location2>] name [on] [off]
Example: turn on the master bedroom light
turn the
master bedroom light on
shut off
the family room reading lamp
turn off
the first floor family room reading lamp
For dimmable devices
[set] [dim] [bright] [raise] [the] [<device
location|device location2|device location location2>] name [by] [to]
<1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|16|17|18|19|20|25|30|35|40|45|50|55|60|65|70|75|80|85|90|95|100>
[percent]
Example: set the master bedroom light to
50 percent
raise
the family room light to 55 percent
increase
the front porch light by 10 percent
For all devices - Status
get [the] status of [the] [<device location|device location2|device location location2>] name
or
<check|what is|what's> [the] status of [the] [<device location|device location2|device location location2>] name
or
<check|what is|what's> [the] [<device location|device location2|device location location2>] name <at|status>
Example: get the status of family room light
what's
the status of the family room light
what
is the the family room light status
what's
the security system at
For all locations - All Lights
<turn|shut> <on|off> all <device location|device location2|device location location2> lights
or
<turn|shut> [all] [the] <device location|device location2|device location location2> lights <on|off>
Example: shut off all family room lights
turn off
all first floor lights
turn off
all first floor family room lights
shut all
master bedroom lights off
Events allow you to configure the voice command for the event in the event properties. You can trigger an event to be run by speaking the event trigger command, or using the syntax below with the event name. Events do not have to have a voice command, but if you wish to command them by voice or by voice using the event name, then the event must be enabled for voice command via microphone, telephone, or both. If you enable an event for voice command by microphone but do not enter a voice command, you will still be able to run the event by voice using the event name.
By event command
event command string
By event name
run event event name
Reminders use the dictation capabilities of the voice recognition engine to allow you to speak anything after the reminder keyword(s). You should be aware, however, that the VR dictionary will not have some words that you may wish to be spoken such as proper names. For example, the dictation engine would not recognize 'George', and although they sound alike, the name Harry would be recognized as hairy. HomeSeer Technologies may provide a way for you to add words to the dictionary at a later date. Reminders only work with the time modifiers above - they cannot be spoken by themselves. Here is the syntax for a reminder without the time modifier:
<reminder|remind me> [<to|that>] dictation list
Example: remind me to
go to the store
remind
me to pick up the dry cleaning
reminder
take the garbage to the curb
Using the "Voice Reminders" configuration page, you can set up reminder labels and associated destination remind methods. For example, you can create a reminder method where the label is "my wife via phone" and configure it to deliver the reminder via a phone call. If this is set up, then the syntax for reminders becomes:
<reminder for label|reminder|remind
label|remind me> [<to|that>]
dictation list
('label' in the above is replaced with one of the voice reminder
names/labels that you created on the Voice
Reminders page.)
Example:
remind my wife via phone that it is time for the appointment
reminder
for Karen to please stop at the store and get some eggs
When a time modifier is used with a device or event command, it will result in an event being created in HomeSeer to carry out the command. These events are created in the "Delayed Voice Actions" group. You can use the HomeSeer Web UI to delete these events or run them earlier, but to cancel the future commands for a device or event by voice, use the cancel commands described here. These commands will only cancel future device and event commands that were created with a voice command (i.e. Only the events in the Delayed Voice Actions group.)
cancel [the] [delayed] [action] [for] [the] event event name
or
cancel [the] [delayed] [action] [for] [the] [event] event command
or (for devices)
cancel [the] [delayed] [action] [for] [the] [<device location|device location2|device location location2>] name
Example: (assume an event called "Party
Mode Start" has a trigger command of "Let's get the party started"
cancel
the event Party Mode Start
cancel
cancel
the delayed action for master bedroom light
The device, device all, and event commands all operate standalone as well as with certain time modifiers. The reminders only work with a time modifier. Here is the list of all of the commands with the time modifiers they can work with - this is the list of all of the voice command types supported in the system (telephone voice recognition adds voice commands for working with mailboxes and messaging and are listed elsewhere).
Device On/Off, Dim, Status and "All" Location Commands |
Command |
turn off the kitchen light |
Status Command |
what is the status of the kitchen light |
All Command |
shut off all first floor lights |
Future Time Period Command |
in 20 minutes turn on the kitchen light |
Future Time Period Command Duration |
in 20 minutes turn on the kitchen light for 2 hours |
Future Time Command |
at 6 PM turn on the kitchen light |
Future Time Command Duration |
at 6 PM turn on the kitchen light for 20 minutes |
Future Day Future Time Command |
on Wednesday at 4 15 PM turn on the kitchen light |
Future Day Future Time Command Duration |
on Wednesday at 4 15 PM turn on the kitchen light for 30 seconds |
Future Date Future Time Command |
next month on the twenty first at 3 in the afternoon turn on the kitchen light |
Future Date Future Time Command Duration |
April first at 11 AM turn on the kitchen light for 45 minutes |
Event Commands |
Command |
run event Party Time |
in 20 minutes run event Party Time |
at 6 PM Let's get the party started |
on Wednesday at 4 15 PM run event Guest Lighting |
next month on the twenty first at 3 in the afternoon Let's get the party started |
Reminder Commands |
Future Time Period Reminder |
in 20 minutes remind me to go pick up the kids |
Future Time Reminder |
at 6 PM remind Karen via phone to leave for the meeting |
Future Day Future Time Reminder |
on Wednesday at 4 15 PM reminder to stop at the cleaners on the way home |
Future Date Future Time Reminder |
next month on the twenty first at 3 in the afternoon remind me to bake a cake |
Cancel Commands |
Event Cancel Command |
Cancel the delayed event Party Time |
Device Cancel Command |
Cancel the family room light |
If you have HomeSeer Phone installed, there are additional commands available to work with voicemail messages and to place calls using the information in your HomeSeer Phone Address Book.
When you are using voice recognition via the telephone, there is an additional command available that is not available via the microphone, and that is "help" - speak this to get a list of the basic commands you can use while accessing HomeSeer via the phone.
After accessing HomeSeer via the phone using the local-access method (pick up a phone in the house and press the pound [#] key) or from a phone outside the house (* and # when you hear your greeting, then enter a mailbox passcode when prompted), here are the commands available to you:
Messaging and Phone Voice Commands |
To leave a message for somebody in their voice mailbox |
Syntax: Leave a message for (mailbox name) |
To leave a message in the default voice mailbox |
Syntax: Leave a message |
To access your voicemail messages |
Syntax: Messages |
To call a person in your address book at their home phone number |
Syntax: Call (person name) |
To call a person in your address book at one of their other numbers |
Syntax: Call (person name) at [the] (number
field name) |
To call a person not in your address book using their phone number |
Syntax: Dial (digits of the phone number) |
